EGT amplifier (DSUB9)...was ist das genau
JUST FOR FUN
Beitrag von JUST FOR FUN »
bin des englischen nicht so mächtig.
handelt es sich hier um eine abgastemeraturanzeige oder ähnliches,was man verbauen könnte ??
EGT amplifier in a standard DB9 connector housing.
Compatible with any K-type thermocouple (not just VEMS EGT sensors)
Works from 10-15V supply, features 2 outputs:
1V / 100C output useful to watch EGT on a DVM: DVM shows 9.90 (V) for 990C EGT temperature. (Junction temp is considered, and no calibration is required.
0-5V output for dataloggers. 1V / 233.3 C
Fahrenheit reading is currently not supported. If you insist on Fahrenheit-scale EGT reading (instead of the 0-5V output), that is you want 1000F=1.000V, write in the order note: not recommended: because there is an offset at roomtemp because 0C=32F not 0F. Effectively: 1000F=1.000V, 800F=0.794V, 1200F=1.206V)
mfg gerd
brainless
Beitrag von brainless »
Gab's einen Abgastemperaturfühler im V8: Abgastemperaturfühler Audi V8 S4 S6 200 20V Turbo S2?
