Audi 100 Avant Q Sport(200 20v look-a-like - A question!!!)
Ignas.quattro
Re: Audi 100 Avant Q Sport(200 20v look-a-like - A question!
Beitrag von Ignas.quattro »
Need to paint some parts :-D
little_e
Beitrag von little_e »
Oh. Was that distributor red???? :roll:
Ignas.quattro
little_e hat geschrieben:Oh. Was that distributor red???? :roll:
They are always red , but some of them have an additional black plastic cover :)
little_e
Yes... although yours seemed more greyish-gunkish :-D
Ignas.quattro
Any ideas on the noise that appears when the clutch is NOT pressed? When I press the clutch , the noise disappears , when I release it - reappears.
Here is the video:
http://www.youtube.com/watch?v=e-yVxsdExrk&
dado
Beitrag von dado »
In most cases, the bearing inside the clutch makes noises when depressing the clutch pedal.
Ignas.quattro
dado hat geschrieben:In most cases, the bearing inside the clutch makes noises when depressing the clutch pedal.
Yes, I know, but this is different...
little_e
I would say it's a bearing inside the transmission, because the bearing inside the clutch has most force on it when the clutch is depressed.
My guess is a bearing inside the tranmission, most probably a bearing on the input shaft, because when you depress the clutch it will stop spinning.
The damage will come by using the incorrect oil and/or running the transmission without enough oil.
...just my opinion though...
Ignas.quattro
So , finally , after so much waiting, the purebred 200 20v USA instrument cluster arrived :D Seems to be in a superb condition and still a virgin, with the VDO sticker untouched :D
Ignas.quattro
Finally installed the temperature display 8)
Ignas.quattro
Found some rare goodies!! Will be preparing and installing them sometime soon, hopefully :D
Ignas.quattro
Already removed velour(it removed very nicely) and was about to put on (replace) the original leather from the current door panels, but the foam turned out to be just in pieces, completely worn out, so I'm now looking for someone to re-glue it back on, because it's too much hassle to make it on my own (including foam , so that it feels exactly like original). I was about to do it on my own, but there different types of glue , different techniques so that I just don't wanna ruin something , because I kind of have one shot to do it right :D
I cleaned them very thoroughly as well, because they looked like they were never ever cleaned , you can check the pictures here , just disgusting :-D
dado
Beitrag von dado »
your pictures don't work mate.
Ignas.quattro
dado hat geschrieben:your pictures don't work mate.
Hmm, that's strange, because they work just OK for me :roll:
Ignas.quattro
Winter-time
DerSportkombiDavid
looks good with original rims. I´ve got "Gullideckel" for winter too, now i´m thinking of doing the same for summer again.
greets David
MfG David
Augen auf und durch!
Ignas.quattro
DerSportkombiDavid hat geschrieben:Hi,
greets David
Hey , thanks!
Gullideckel you mean the ones from A8??
DerSportkombiDavid
no, the ones that you´ve got on your car, but i have 6Jx15 4x108.
greets David
MfG David
stwquattro
Beitrag von stwquattro »
She´s looking gorgeous, Ignaz.
Hope u r doing good! :)
Best regards from Germany!
Sebastian
1993 Lada Niva 1600
Anatolik39rus
Beitrag von Anatolik39rus »
Didžioji Audi! Aš taip pat neseniai davė interjero travertinas, bet jis dažytos juoda, trinamas lėtai!
Ignas.quattro
Anatolik39rus hat geschrieben:Didžioji Audi! Aš taip pat neseniai davė interjero travertinas, bet jis dažytos juoda, trinamas lėtai!
Please show me some pictures if you painted your interior in travertin - that is what I understood.
I also understood that you've used a google translate :D
Ignas.quattro
stwquattro hat geschrieben:She´s looking gorgeous, Ignaz.
Sebastian
Private Messaged :)
Anatolik39rus
Hi Ignace, next week I'm going to Russia, on the way back will go through Belarus and Lithuania, will pass through Kaunas
  really want to see your avant we floor area dries on it, you turned it into a masterpiece)))
I'm two years on the Russian site drayv2 there is a social network for cars, but decided to register and then, I wanted to gain experience for more)
By the way, here's a reference on travertine sauce: (
http://forum.group44.de/viewtopic.php?f ... &p=1408811 # p1408811
Ignas.quattro
Hey everyone!
Finally as wide as I wanted it to be , now I need it slightly lower :D
DerSportkombiDavid
surely one of the best Avant Quattro Sport around. But you even know :D .
Greets David
MfG David
Ignas.quattro
Greets David
Thanks, very nice to "hear" it :) I wish the car looked at least half as good in reality as it does in the pictures :D But it's a daily driver for me, so one can expect torn and worn leather seats, rust here and there and other crappy things... :cry:
Snow Racer
Fuhrpark: 1990 Audi 100 MC2 (Current)
1990 Audi 100 NF (Wrecked but alive)
Beitrag von Snow Racer »
hmm... is it only exhaust tips or whole exhaust?
true... I didn't expected to see the ugly spots but as you said it was lousy paintjob :(
and I have the photos [evil_laught] MWuhAHAha! [/evil_laught] :twisted:
edit - now you have the anti lock button also :-D
