Janne
Beitrag
von Janne »
Anyone knows does the 215/45-17 ET35 wheels fit to standard 87´ typ44 100 if i install KAW 55/35 lowering set to it?
yvma
Beitrag
von yvma »
hi is it a fronty or a quattro??
for the front wheels its gonna be ok but for the rear?
yvma
oldsklaudidub
Beitrag
von oldsklaudidub »
Should fit, but you might need some spacers up front, 5-10mm depending on how the car is sitting.
Also that tire width is fine, Ive fit 225 with slight rubbing on the front steering knuckle, nothing a 5mm cound not fix.
